Let's try this again.
Maxstar 200dx bought used.
worked for 2 or 3 hours on 120v/60hz @ 1ph.
brought to another shop with plug in which we use for 180amp and 225amp mig welder. have used it multiple times with various MIG & ARC units.
wired up Maxstar 200dx for use according to operators manual and double checking wires coming from transformer. All was well.
plugged 'er in. used for 30 or 40 minutes. no error codes displayed. functioned as normal. laid some tig beads on 316 SS. It then started to smoke up, so we shut it off. opened the case up to find that the front-most 450v 1500uf capacitor had leaked electrolyte from underneath. it must have leaking from the time I started to use it, as I smelled it long before the smoke was visibly pouring out the back. It was even on and striking arcs just seconds before shutting it down.
So thinking that it was just the caps and the 3 items (diode, igbt, voltage reg) on the heatsink on the PC2 input power board, I replaced the two large caps and those 3 items, inspected all components on the board, and used Miller Dynasty 200dx tech manual as a reference to test things they have in common.
She won't start up anymore. I can hear a faint humming noise, but no display. Looking at Power Module PM1 to be the culprit. Any other ideas before I test? Is PM1 easy enough to replace?
