Greetings all.... great to be here among the pros. I recently purchased this used 302 with air pack Serial MA18xxxxM Kohler Command Pro CH 750. It has an unsteady idle and backfires when comming down off 3500 rpms at times. Has a slight serge at higher rpm's also, takes a while to rev. up at start up. Compression test....130 one side and 150 on the other. does this sound like a valve problem or what can you suggest to do. 1000 hrs on engine and 750 on compressor. Thanks for any input.
Trailblazer 302 low compression
You must think that we need the serial# for stupid maybe criminal reasons. but no I take that #, punch it into a tech site, and it tells me everything i need to know. You blanking out the #'s doesn't help your case...
Welcome to the site, but it seems either we don't get serial#'s, or get partials. Tough to troubleshoot on vagueness.Last edited by cruizer; 02-12-2015, 05:03 PM.
Originally posted by Schafe View PostGreetings all.... great to be here among the pros. I recently purchased this used 302 with air pack Serial MA18xxxxM Kohler Command Pro CH 750. It has an unsteady idle and backfires when comming down off 3500 rpms at times. Has a slight serge at higher rpm's also, takes a while to rev. up at start up. Compression test....130 one side and 150 on the other. does this sound like a valve problem or what can you suggest to do. 1000 hrs on engine and 750 on compressor. Thanks for any input.
KevinLincoln ranger 305g x2
Ln25
Miller spectrum 625
Miller 30a spoolgun
Wc115a
Lincoln 210mp
F550 imt service truck
Thanks Guys
Cruizer- Try this MA80002M I thought we were not supposed to give full serial for some stupid reason. Sorry bout that. I will check the spark strength. I hope I don't need to pull those coils because I think the compressor would have to come out first. Tryagn5- I have changed oil filter,plugs and fuel filter. Used a 10-30 regular grade oil. Only oil I use around here is 15-40 Diesel oil so I just bought some regular stuff and put it in. Which oil would you recommend? Fuel was right full when I got it but I also thought of that. I will drain it and put in new after the other tests. P.S. I was also leaning towards the hydraulic lifters not pumping properly. I did 2 compression tests and each time it took different readings taking less or longer revolutions to build up each time. I may be jumping the gun here thinking the issue is more serious then it really is and that's why the guy sold it.
Pull the valve covers off, see if you have a loose rocker and a bent pushrod. This is generally caused by running dinosaur oil in a cold environment. Moisture from the oil gets in the lifters and freezes. This bends a pushrod.
Now the compression is normal so that's not the issue.
Oil must be a diesel or 4 stroke motorcycle oilLast edited by cruizer; 02-13-2015, 10:18 AM.
