I have been on the search for stubby gas lens parts for a model 17 torch since I bought my new Syncrowave 210. The torch is a lot bigger than the #9 I had, but it seems to take the heat better for extended welding periods and high amp aluminum work. But I find myself having a hard time getting in tight spots. So im looking for some help, I would like to buy the pieces/parts, and a couple of somethings, not just 1 kit per tungsten size. Honestly I only see myself needing 1/16 and 3/32 sizes. On the rare occasion that I run 1/8 tungsten, I can use standard cups and collets. Can anybody point me in a good direction to buy these things separately?? Thanks in Advance.Zach
#17 TIG torch stubby gas lens parts
Originally posted by Sledpuller555 View PostI have been on the search for stubby gas lens parts for a model 17 torch since I bought my new Syncrowave 210. The torch is a lot bigger than the #9 I had, but it seems to take the heat better for extended welding periods and high amp aluminum work. But I find myself having a hard time getting in tight spots. So im looking for some help, I would like to buy the pieces/parts, and a couple of somethings, not just 1 kit per tungsten size. Honestly I only see myself needing 1/16 and 3/32 sizes. On the rare occasion that I run 1/8 tungsten, I can use standard cups and collets. Can anybody point me in a good direction to buy these things separately?? Thanks in Advance.Zach
you may need to call or email with an inquiry though..
The whole kit is inexpensive enough at $50... you might consider getting the whole shebang..
Our Stubby Gas Lens Kit fits all 17 and 26 Series air-cooled and 18 Series water-cooled TIG torches, including LINCOLN® PTA-17, PTA-18, and PTA-26 TIG torches, Miller® Diamondback DB17, DB18, and DB26 TIG torches, as well as Weldcraft® LS-17, WP-17, WP-18, and WP-26 TIG torches.Our stubby gas lens kit allows you to useLast edited by H80N; 02-10-2015, 12:32 PM..
Part numbers for 3/32, Collet, lens, and insulator. All you need now is a nozzle/cup for a 9 torch.Attached FilesLast edited by ja baudin; 02-10-2015, 12:44 PM.sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Do you need a different plastic insulator for a gas lens vs. a regular collet body?
I'm referring to the #9 torch though.MM 211 W/ Spoolgun
Diversion 180
Spectrum 375 X-TREME
Portable Victor O/A
Palmgren Bench Drill Press
14" Evolution Dry Saw
IR 60 Gal. 3 HP Compressor
Speedglas 9100x
My Brain
