Been doing a lot of reading on the Forum and wherever I could find any information and I came across an interview with a metallurgical engineer.
Thomas J. Black, manager of hardfacing and high-alloy products for The Lincoln Electric Company in Cleveland, OH
The article went on to talk about the various metals and alloys that construction equipment are fabricated with and goes on to say that E7018 should not be used in hardfacing applications as a buildup material since it has a tensile strength of only 70,000 psi and a yield strength of only 58,000 psi.
The article goes on to say welders are using the E7018-type welding rod or wire to construct the buildup layer, when that material is too soft and too weak for the application. Also welders often select a hardfacing material that is not suitable.
What rods do you use on construction equipment? Which rod and on which parts/areas of construction equipment.
Have you been calling the manufacturers and asking them what materials the construction-equipment components are made from to determine which rod or wire to use?
How are you determining the hardfacing rod or wire you are using for abrasion or impact?
I know the Lincoln series of books and the miller books are a fantastic source on metallurgy but I do see many welders are using E7018 as the rod to go to.
Just asking and Thanks for your replies.
