tig torch
  • Cgotto6
    Either way this machine will never tig weld, regardless if you get the connection figured out.
  • elkinssilver
    If it's an add on they did a good job. Looks factory to me.
  • H80N
    Originally posted by elkinssilver View Post
    Many thanks for the info. It's funny... even the owners manual didn't show anything about the 2 remote receivers on this welder.
    Thanks for the help guys.
    A longshot but....
    Might be that somebody adapted a Lincoln 14pin to the welder...so that they could run an LN25..??
    I seem to remember that they are "Clocked" in a different position so that the shell and insert are not placed the same... so not interchangeable.. but that would have to be checked and confirmed..
    This is just a wild conjecture..
    Cruizer would probably be able to shed more light on the facts of this...
  • elkinssilver
  • H80N
    The serial # is KF954083.
    That number crosses to a MM250X
    Owner's Manual Search Results Model Name: MILLERMATIC 250X
    Serial Number: KF954083
    Made late 1995
    maybe a pic of the front panel and connectors..??
    Manual
    http://www.millerwelds.com/om/o1308h_mil.pdf
  • elkinssilver
  • H80N
    This welder has the 10 post receiver and the 14 post receiver on the front of the panel. I know it's confusing. I've never seen one like it either,.
    Well you sure have me confused...
    I can find no reference to a 14pin in the manuals for the MM250, MM250MP or MM250X
    Again... the SERIAL NUMBER will clear up a lot...
  • elkinssilver
  • H80N
    Originally posted by Cgotto6 View Post
    That is a mig welder. The port your probably trying to plug into is the hook up for a spool gun. Not going to tig with it.
    believe that is a 10pin..... no way it would align with the 14pin placement...
  • Cgotto6
  • H80N
    Sorry for the confusion ... but this is a millermatic 250 cv.dc arc welder/power source/wire feeder. I'm not sure when they made them. I was also wondering if it had a high frequency unit in it. Thanks again
    No "HF".....
    not sure where you are trying to plug in your 14pin.... because the MM250 does not have one....
    again... serial number would be most helpful...
  • elkinssilver
  • H80N
    No sir, They're not bent, they just don't line up. I'm trying to test the tig function of a millermatic 250. I just wanted to take the tig torch off my xmt 300 but the pins don't line up.
    You have me somewhat confused... the Millermatic 250 has NO TIG function...that I know of..
    are we talking about a Sync 250 Maybe??
    http://www.millerwelds.com/om/o1308n_mil.pdf
    could you post the serial number??
  • elkinssilver
  • H80N
    Can anyone give me advice on aligning the pins on my 14 post remote for my tig set up? Thanks in advance
    Have you somehow bent the pins in the 14 pin plug on the pedal/hand control??
    if so... how bad??... pics??
    depending on how severely bent... they might be straightened or the connector may need to be replaced...
