Can anyone give me advice on aligning the pins on my 14 post remote for my tig set up? Thanks in advance
tig torch
Originally posted by elkinssilver View PostCan anyone give me advice on aligning the pins on my 14 post remote for my tig set up? Thanks in advance
if so... how bad??... pics??
depending on how severely bent... they might be straightened or the connector may need to be replaced....
Originally posted by elkinssilver View PostNo sir, They're not bent, they just don't line up. I'm trying to test the tig function of a millermatic 250. I just wanted to take the tig torch off my xmt 300 but the pins don't line up.
are we talking about a Sync 250 Maybe??
could you post the serial number??.
Originally posted by elkinssilver View PostSorry for the confusion ... but this is a millermatic 250 cv.dc arc welder/power source/wire feeder. I'm not sure when they made them. I was also wondering if it had a high frequency unit in it. Thanks again
not sure where you are trying to plug in your 14pin.... because the MM250 does not have one....
again... serial number would be most helpful....
Originally posted by Cgotto6 View PostThat is a mig welder. The port your probably trying to plug into is the hook up for a spool gun. Not going to tig with it..
Originally posted by elkinssilver View PostThis welder has the 10 post receiver and the 14 post receiver on the front of the panel. I know it's confusing. I've never seen one like it either,.
I can find no reference to a 14pin in the manuals for the MM250, MM250MP or MM250X
Again... the SERIAL NUMBER will clear up a lot....
Originally posted by elkinssilver View PostThe serial # is KF954083.
Owner's Manual Search Results Model Name: MILLERMATIC 250X
Serial Number: KF954083
Made late 1995
maybe a pic of the front panel and connectors..??
Manual
Originally posted by elkinssilver View PostMany thanks for the info. It's funny... even the owners manual didn't show anything about the 2 remote receivers on this welder.
Thanks for the help guys.
Might be that somebody adapted a Lincoln 14pin to the welder...so that they could run an LN25..??
I seem to remember that they are "Clocked" in a different position so that the shell and insert are not placed the same... so not interchangeable.. but that would have to be checked and confirmed..
This is just a wild conjecture..
Cruizer would probably be able to shed more light on the facts of this...Last edited by H80N; 01-31-2015, 02:40 PM..
