hf starts but no gas flow, the snap start box does not have pre or post flow dials serial # kk 124230, I have a supplementary data sheet form:s183 502a says G gas valve control connection; 24v applied to socket turns gas valve on 0 v ac turns off. H + 15v dc when open circuit is present at weld output receptacles 0v dc when arc ignites or contactor deenergizes I common conection for socket H, does this mean my foot pedal is wrong, 14 pin miller, also this combo was on a automated unit, the maxstar 152 serial # is kh503285, yes I have gas and torch works I tried it on another machine, it did have Teflon on inlet hose when I got it, I"ve never seen this hf box with out pre post controls was this a later version or something oddball and would it be a delayed arc/postflow, Thanks Pat
Maxstar 152 w/ snap start II no gas flow
Originally posted by cruizer View PostIs it still an automated unit? The pre and post flow that used to be controlled with arc sensing was removed. Soooo it was modified somewhat. And thats an unknown that we can't help you with.
