Propane torch
  • Propane torch
    Hello folks I need help again I have been using a propane torch for some time like 40 yrs and have used a Rose bud here and there using the same regulators as acetylene the question is are there any regulators specifically for propane? I never had any problem using same gauges but the question came up help please
    Here is a statement directly from Smith:
    (I use propane instead of acetylene too - with the acetylene regulator)
    FAQ
    Question:
    Can I use an acetylene regulator on an LP tank or an LP regulator on an acetylene tank?
    Answer: You can use an acetylene regulator on an LP/alternate fuel gas tank, but never use a regulator designed for LP/alternate fuel gases with acetylene.
    LP/alternate fuel gas regulators are typically capable of producing outlet pressures as high as 50-60 psi, whereas an acetylene regulator is designed to operate at pressures slightly higher than 15 psi. Because acetylene becomes very unstable at pressures over 15 psi, using an LP/alternate fuel gas regulator would enable to the operator to increase the pressure to a point where it is unsafe as acetylene is unstable when released from the cylinder at pressures greater than 15 psi.
    "Beware of false knowledge; it is more dangerous than ignorance." ~George Bernard Shaw~
    Airco 300 Heliwelder
    Dialarc 250 AC/DC
    ESAB 161
    Invertec v250 and v300 Pro
    SA200
    Spectrum 700 plasma
    MM210
    Miller HF-15-1
    Dirty ugly tools - perfect
      Propane torch
      Thanks very much appreciated
