Are these reliable meaning no leaks . I ask because Im mobile and connect and disconnect every time I have to move between locations. And its time consuming.
inert gas quick connectors ?
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#Tags: None
Originally posted by eecervantes83 View PostAre these reliable meaning no leaks . I ask because Im mobile and connect and disconnect every time I have to move between locations. And its time consuming.
if you need to do a lot of connect reconnect... you might look into these qwik connects
https://www.arc-zone.com/index.php?m...ubg5k1lur6j8fnLast edited by H80N; 01-17-2015, 12:22 PM..
inert gas quick disconnects
Compressed air fittings can and do leak....but the guys that use those never soap and check for leaks, anyway--since they're not the one who has to buy the gas. I'd suspect that 10-25% of inert weld gas is leaked away in many shops.
Still periodically soap and check every connection.
I changed out both shop and portable gas hookups, had pigtails, etc. made up
for q-d inert fittings.
Having a small bottle for portable on-site, leak down while 50 miles away from shop, on a weekend costs more that going the fitting route, IMHO.
Originally posted by H80N View Postif you need to do a lot of connect reconnect... you might look into these qwik connects
https://www.arc-zone.com/index.php?m...ubg5k1lur6j8fnEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Thanks.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
we have quick connects on the suitcases at our shop the problem with the quick connects is you need to have a female quick connect on the back of the box that way no dust gets in when the lines are disconnected if dust gets in plan on takin down the gas valve inside the box and cleaning it .sisne the owner doesn't want to go through the trouble about makin pig tails for our boxs i keep a role of electricao tape that way i can seal up the inlet on the back of my box while i'm moving to another location.
