Pulling hair out here.
Through the help of the miller tech guys on the phone...
we tried to figure out why the motor would only work at 80 wire speed and above...
so through some testing we thought it was the relay. Put in the new one. NO. Did not resolve it.
Then we suspected the rheostat. Put in new one. NO. Did not resolve it.
Something I noticed was that the longer I let the motor turn ( with a clamp) on the gun trigger...the lower I could dial the wire speed down and the motor still turn. So in other words as the motor got warmed up the better it worked. Or the more normal it worked. So I took apart the motor and found one of the magnets inside the tube was not attached any longer. There are four and one of them was loose. What I was dreading ( a new motor) was now a reality. I tried to fix the old one and re-glued the one magnet but got it a little offset. I tested it after the fix on a car battery. It stopped working all together.
So I angrily ordered a new $200 motor. I put it on tonight, hook up the wires. Hit the trigger and nothing. No motor turn. I took the wires back off the motor and put some leads on those two wires. I see nothing on those two wires. No voltage. No matter tap 1 thru 4 or rheostat setting. No voltage. Nothing.
I have no idea what has now happened to this welder.
It has a new relay, new rheostat, and now a new motor.
Frustrated would be an understatement.
If anyone can offer anything thanks x 100.
