Hi I'm looking for a new welder for my garage. Mostly auto restore welding sheet metal,exhaust, subframe connectors. I have plugs for both machines in my garage. Would the 190 be overkill for sheet metal or should I just go with the 190 as I may need to weld thicker stuff down the road. Thanks guys. This will be my first welder but I use them at work and use friends.
millernatic 141 or 190
Usually once you get started welding you become HOOKED ! With that I would not even consider the 141. If you need the machine to be portable the 191 is only 35 pounds and 240 volts. However if weight is not a issue might consider the 211. A few more bucks but a little more power and it is multi volt, 120/240.
Shop around and see what local supplier will give you the best deal . Get a price with a tank too. A package deal with more goodies will result in a better deal. Machines are priced pretty close to all suppliers, not too much room for deals.
Definitely the 190 (or 211)
You can dial down the 240v machines but you can't dial up the 120v machinesEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Buy the biggest u can afford. Period.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Originally posted by Danny View PostEd,
You aren't very fond of the arc characteristics of the 211 correct?Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Originally posted by Broccoli1 View PostNot at all.. but I'm spoilt with the Passport.
The 190 being an inverter based unit, like your Passport, has me wondering if the 190 arc characteristics are far superior to the 211. If the V/A curve supplied for the 190 is accurate, the 190 may offer a little more top end power than the 211.
If I am remembering your description of the 211 arc characteristics, it performs similar to the MM 180. On the 180 once you go over about 150 amps, the arc starts becoming harsh, and it becomes difficult to keep the spatter level down.
For thin ga sheet, the MM 180 couldn't come close to competing with a Lincoln Power MIG 180C. The 180C has an excellent low end for thin ga sheet. If your looking for a thin ga sheet metal unit, the Power MIG 180C is definitely a unit to consider.
