syncro 350 lx start up
  • sledsports
    A little follow up... Its headed over to the local miller repair guy. I am afraid of it.
  • sledsports
    That my explain the hard light ups and going out from time to time. Maybe my machine doesn't run correctly. I'll yank the covers off and take a look. Thanks Cruizer.
  • cruizer
    With many machines that startup code is the software installed, no idea if that is the case here. Because of the decimals, I think not, If I had to guess, your Hall (lem) socket is corroded, and your going to have future problems
  • sledsports
    Serial number- LC561488.
    Incoming power is 230 volt single phase on a 125 amp breaker
    #4 3 conductor direct to the breaker about 25 feet from the box.
  • sledsports
    started a topic syncro 350 lx start up
    I serviced the cooler a couple a months ago and noticed something different during start up. Different numbers come up that I haven't seen before and as much as I use this machine they haven't changed. It seems to run fine. First 18.7 pops up in the voltage dro and 766 in the amp dro. Then they disappear and a -.5 pops up in the volt dro. Then the normal last amperage used is displayed. These numbers hasn't changed. Anyone make heads or tails of it?
