Rust proofing the back side of a auto sheetmetal weld
  • Rust proofing the back side of a auto sheetmetal weld
    Any one know how to rust treat the back of a sheet metal patch before welding it into place. I'm not sure if it can be done because of heat and cleanliness.
    Clean as best you can & use weld through primer. Weld in patch & then drill an access hole so you can get a nozzle inside & use whatever paint or product you are comfortable with. Then pop a rubber plug in & call it day.
    Eastwood sells some products for just this purpose. One good one is called rust encapsulator.
    Stop rust in its tracks by treating car parts with rust encapsulator, rust converter, abrasive grinding wheels and other ways to leave metal shining like new.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      That's my best advice yet. Thanks
        I don't know if it's still available. We used a product from Texaco; rustproofing grease. The stuff lasts at least 40 years, it's still sticky if you squeeze through the crust.
        Dynasty 280DX
        Bobcat 250
        MM252
        Spool gun
        Twentieth Century 295
        Twentieth Century 295 AC
        Marquette spot welder
        Smith torches
          Cosmoline is used by the military to coat weapons. Royal pain to get off. Will last longer than any of us will live.
          Miller 211 AutoSet
          Miller Dynasty 200 DX
          Thermal Dynamics Cutmaster 42
          "The Sleep of Reason Produces Monsters"
          Francisco Goya
