Stargon???
  • H80N
    Originally posted by snowbird View Post
    you got me H80N, i was too lazy to go to my docc. and went easy google, once again cutting corners doesn't pay
    No fault... No Foul...
    Heck…. There are so many different gas blends marketed under dozens of tradenames…
    About impossible to figure them out without a cross reference…
  • snowbird
  • H80N
    from a quick search on praxair site there is no such thing as stargon being a tri-mix gas. What is the content of that mix?
    (remember it was a quick search)
    what kind of machine, wire, wire size, feed, voltage, gaz cfh and thickness and material you're attempting to weld?
    Actually.....
    if you check this gas cross reference under
    ARGON / CARBON DIOXIDE / OXYGEN BLENDS
    We will find STARGON listed as 90/8/2
    http://www.aoc.com.mx/biblioteca/tab...PROTECCION.pdf
  • snowbird
  • cruizer
    Depends on if its a SS or CS blend, with that mixture it sounds like a SS blend, so Argon,CO2, Nitrogen and oxygen, 100% stainless steel.
  • ericher69
    Stargon???
    Are you short arc welding or spray welding?
    Believe your stargon is mainly for spray welding.
    Someone in the know should be able to help you out.
  • red79c3
    started a topic Stargon???
    Stargon???
    Hello All,
    I'm using Stargon (90/8/2) for the first time and it just keeps farting and spurting on me every now and then.
    When I use Argon (75/25) I weld just fine.
    Any and all help please...
    Thank you
