Originally posted by Portable Welder
View Post
But the 350P-alum that I demoed fed 4943 like a champ. It was a shorter lead like 15ft, so I think that made a huge difference. It also has a slave drive in the cabinet that only assists the main pull motor in the gun so it is gentler on the wire. Since the 350P-alum slave drive cannot over power the pull motor it does not have to be synchronized (SUP value ) with each other. And roller tension is not tricky for soft wires like the standard 350P which can really deform the wire.
There is an idiot guide in a pop out shelf below the display panel in both the 350P and 350P-alum, and believe me the alum version is much simpler. Set it to the chart and off you go. Really simple. 5 minutes after power up should do it.
If I had it to do over again though I would go with the Linclone and the pulse on pulse, as alum mig is always spray, and high speed pulse just flares the arc, which is helpful for thin metals and large wire. High speed pulse is useless on 1/4" and thicker alum plate again as it is always in spray and the pulse mode just fades out in the process and lowers your overall voltage. That is where Pulse-on-Pulse would be helpful. High speed pulse for arc modification, and low speed pulse for bead cadence.
Just my 2 cents. I could be delusional.
