Trailblazer 301g Troubleshooting
  • Trailblazer 301g Troubleshooting
    Has any1 here ever owned or used a trailblazer 301g ac/dc machine and tried to air arc with it? As it states in the owner´s manual that it is capable of this process. I did and my results were a f´d up machine that doesnt have any weld output and no longer idles down.
    WORK HARDER.....MILLIONS ON WELFARE DEPEND ON YOU!!!!
    I air-arc with mine, no problems.
      air arced off every machine owned...
      I would bet you cranked it to max output and arced away....when ever air arcing off any welder never exceed 75 percent of max output. So on a tb 301set it at 250 amps, run 3/16 carbons and away you go. If set at max the machine will rev past the governed speed then lug as you dig with the carbons, not a good thing. Fyi i put over 1000hrs of air arcing on tb 301, 302's, and lincoln 305gs, i next to never grind, i use air arcs a lot.
      Kevin
      Lincoln ranger 305g x2
      Ln25
      Miller spectrum 625
      Miller 30a spoolgun
      Wc115a
      Lincoln 210mp
      F550 imt service truck
        You would think miller would put some kind of fuse or breaker in line to prevent screwing up the board. Or atleast some type of warning in the owners manual stating not to exceed a certain setting.
