Charge us a couple dollars more and put lifting eyes on so I can lift the machines up in the air to weld over the sides of trucks and things of this nature.
Complaint about Miller mig welders.
Hows this a complaint..
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Miller used to put lifting eyes on many of their machines. I can't tell you how many times I have hoisted an old mm200 to get to some high stuff. I wish they still put them on as well. The 252 is pretty awkward to rig for hoisting, and slinging around the machine doesn't let you open the machine without taking the sling off. Also a quick pick is a pretty good way to secure an engine drive for the weekend if you have a crane on a jobsite.
Looks like miller still puts lifting eyes on their larger engine drives. But as anyone who has loaded a miller 252/350 with a forklift a lifting eye is much better rigging practice. Very unstable center of gravity.Last edited by Mikey Welds; 01-01-2015, 09:59 AM.
I have a MM250 I bought back in the early 90s. It had a couple plastic plugs on top, remove them and there is a threaded hole underneath each, going into the frame. I made a couple eyes and screwed them in, allowing me to pass a chain thru them and then over the forks of my forklift. Problem with fixed eyes, it would interfere with the access door opening completely.
I would assume the later versions of this machine (251 and 252) would have something similar.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
I think a recessed folding lift eye would be awesome
Or, a cheaper alternative is a fixed lift eye, with a matching half moon cutout in the lid."Beware of false knowledge; it is more dangerous than ignorance." ~George Bernard Shaw~
Airco 300 Heliwelder
Dialarc 250 AC/DC
ESAB 161
Invertec v250 and v300 Pro
SA200
Spectrum 700 plasma
MM210
Miller HF-15-1
Dirty ugly tools - perfect
Originally posted by Portable Welder View PostCharge us a couple dollars more and put lifting eyes on so I can lift the machines up in the air to weld over the sides of trucks and things of this nature.
http://www.millerwelds.com/products/...ries_swingarc/
Walker, Many of us have the MM units and dont want the bigger units that have a feeder on top because we have to roll them around in limited space to weld around gravel trains etc. where a fixed rotating boom wouldnt solve the problem, many of us have a hilo or a overhead crane and a lift lug on top would come in very handy, I would certainly pay another $ 50.00 for that option that I had on my old MM 200
The day I bought my MM252 I said this is ridiculous, it needs an eye. As there isn't a good way to install one, I promised myself I'd build a cage. I haven't yet done it. We now load it in a pickup by rolling it into a loader bucket. a lifting eye would be easier, and safer.Dynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
I like having it on my MM200 and Sync. It would be a pain to load them otherwise. Whenever I need to weld up high I just use an LN-25. Bit of a pain if you don't already have the right machine to run it from in the shop, but certainly easier to maneuver. Are you using gas when doing this? If so, how are you attaching the bottle?
Do the newer machines not have that center divider that the eye was mounted on like the MM200?
Walker, My current Push pull Cobra 260 mig aluminum mig welder has a lifting lug so we lift it with the bottle on.
When doing steel I have XMT 304 with a S-22 P12 suitcase feeder that I have to use, However there are times when we need to have 2 migs inside the box so we run our suitcase feeders in off the truck instead of being able to use the Miller Vintage or my new 252.
