XMT 304 is Dead
  • XMT 304 is Dead
    Unfortunately we were air arcing today running about 325 amps, we finished, came back to turn it on after lunch and it was dead, no code no nothing.
    Stock # 903471
    Serial # LA195408
    What might be the problem and how much money might we be talking.
    If there is no display then likely a wall breaker issue, did you check them?
      Yes, I checked the breaker in the panel which was fine and then I tried a different plug.
        I just went and plugged it into a third plug and made sure the 2 circuit breakers on the back arent popped and they were not, Im going to take the cover off and verify power in and out of the switch.
          Okay, I'm pretty sure I found the problem, I have power going into the switch, when I was fumbling with the tester on the output side of the switch the machine popped on and as long as I kept side pressure on the wire the machine powered up and allowed me to change settings, it does not feel like a loose wire but more like a bad connection inside the switch.
            Is this switch something I might find from McMaster Carr, Grainger, electrical supply house or will I be forced to order it from Miller.
              Try these guys...
              just enter the part number from the manual...
              Shop Miller4less online. Miller4less
                Looks like I'm in luck, My weld supplier has a used switch that hes going to give me.
                  That's good news - good luck with your machine
                  "Beware of false knowledge; it is more dangerous than ignorance." ~George Bernard Shaw~
                  Airco 300 Heliwelder
                  Dialarc 250 AC/DC
                  ESAB 161
                  Invertec v250 and v300 Pro
                  SA200
                  Spectrum 700 plasma
                  MM210
                  Miller HF-15-1
                  Dirty ugly tools - perfect
