I have a miller AEA 200 LE.the 120v power outlet on front panel low right don't when welder is in weld position the other 2 outlets work in power mode.can you help me. Thanks.
AEA 200 LE when in weld mode the 120v outlet in low left conner dose not work.
If it is the 100 hz outlet designed to operate when welding, I had a similar problem which I was unaware of. I found the problem as the result of a no to erratic weld output. It ended up being a bad diode. I called Miller technical support and they walked me through a diagnosis process to find the bad diode. They were very helpful. I would suggest you do the same.
For me my output at the 100 hz (right) outlet was around 35 volts. I also had a secondary issue we identified which was charging of the battery at 16 volts when the unit was running. Not sure if this helps but I know they can help you if you give them a call.
