Bobcat 225 governor issues
  • Buttsy
    I took the carb apart last night. Found some crap in bowl and cleaned jets. I'm gonna put back together tomorrow night I let you know how I make out. Thanks for the reply
  • eecervantes83
    I had this same problem as you describe. My fuel line was pinched from the pump to the carb..
  • Buttsy
    started a topic Bobcat 225 governor issues
    I bought a bobcat 225 with bad engine. It's the robin eh65. I got a us done off ebay that was off a side x side. I had to change crankshaft on new one because it didn't have the threaded end. Now I can't get it to rev correct I messed with springs adjustment. Everything when I set at 62 hz. It jump as all over and when I weld it bogs down to about 45 hz and won't rev up to compensate. Also with run/idle it won't rev up when striking arc but it will with power tools ? Any help would be great.
