I purchased a used invision 354 mp with a 22A wire feeder and a new Bernard 300 amp gun a few months ago. Tried it out it weld great. Just got around to wiring it up and do some welding. Welder comes on feeds wire volt adjustment works wire speed adjustments work but can't get arc. Not sure what the problem is would be very thankful for any help on where to look for the problem, Thanks
Invision 354 problem
Originally posted by woodcrafter8o View PostI purchased a used invision 354 mp with a 22A wire feeder and a new Bernard 300 amp gun a few months ago. Tried it out it weld great. Just got around to wiring it up and do some welding. Welder comes on feeds wire volt adjustment works wire speed adjustments work but can't get arc. Not sure what the problem is would be very thankful for any help on where to look for the problem, Thanks
Cruizer
Really want to thank you for the help with this problem. Finally found what the problem was. ME!!! I know you've heard the saying You have to be smarter than the equipment you are operating. Holds true here for sure. Didn't have a wire from the wire feeder to the positive side of the power source. put that wire on now it welds like a champ. Guess that's what happens when you let a carpenter hookup a wire welder. Want to Thank You again for the help and advice have learned alot about this machine while trying to find the problem.
Thank again
Jeff
