Hi guys. Im welding up some re bar forms with a Miller 350p and I have problems with the wire sticking to my tip. The wire is not welded onto the tip just after 10 minutes of welding a small ball forms just on the side of the hole where wire comes through on the tip enough to cause the wire to start jamming.. jumping and the arc to act weird. Is it my arc length or my wire speed thats the problem? I use anti splater but it must be my settings. Iv made sure my work piece is ground well.
Wire sticking to tip on miller 350p
Quick tip: either you are too close with the gun and or your wire speed is too slow.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
