does anyone make a more flexible cutting lead for plasma cutters my says in a coiled mess anyhelp
plasma
No and the reason for that is that there is alot going on in the torch cable, your going to have a gas line, that you don't want to twist or bend, copper conduit, , a twin line trigger, that if bent would likely short to the conduit, and likely a couple of saftey cables, same as the latter. Though the cheaper the plasma, the cheaper the insulation is on the cable....
