44D replacement starter motor
  • 44D replacement starter motor
    Having a hard time finding the correct OEM part number for a replacement starter motor. I recently purchased a government 44D Trailblazer trailer mounted, (s/n JJ409052). Only problem was it did not have the starter motor in it. Powered by a Continental TMD 27 motor. So far the Delco p/n I have found is 10461487. Came across a miller p/n 114-773 in an old manual. Purchased one on EBay but it did not fit properly.Came across a miller p/n 114-773 in an old manual. Can anyone give me an original mfg. and or part number for a starter motor
    Not a Miller part, so you'll have to go under the engine serial & code#
      The contiental tmd27 are a junk engine. They are known for throwing rods through blocks. Have u turned over the engine by hand...(i normally use a bar and the teeth on the flywheel) to confirm the engine is free. Fyi the case 1835b and c skid loader used this engine. Also that engine is a very valueable to someone who needs it. It is very hard to get parts for and is of weird dimesions so repowering can be difficult. If you need a starter count the teeth on the flywheel as this will be needed.
      Kevin
      Lincoln ranger 305g x2
      Ln25
      Miller spectrum 625
      Miller 30a spoolgun
      Wc115a
      Lincoln 210mp
      F550 imt service truck
        Here is a link to the engine info page..
        and parts catalog..
        My Blue Stuff:
        Dynasty 350DX Tigrunner
        Millermatic 200
          Have TMD-20 local autoparts store was able to order parts with engine ser. #
