I don't have a lot of experience so am looking for advice. My needs are: I don't need multi plug of 211, would be welding nothing heavier than 3/16 but usually 1/8 down to 18 ga. Would like to use .023 wire. Leaning towards 190 because of inverter which I understand gives a little more stable arc. Any suggestions or advice would be greatly appreciated. Thank you
Advice for a new welder (MM190/MM211)
Consider duty cycle when you are buying a machine. For example a 30% duty cycle means that the welder is rated to weld at that output level for 3 minutes total out of a 10 minute period before requiring a break. At the 100% duty cycle output level of the machine it can perform constantly.
Are both machines on the build with blue promo right now?MillerMatic 251
Maxstar 150 STH
Cutmaster 42
Victor Journeyman OA
The MM211 is a proven design that got great reviews and had minimal problems. The MM190 is like buying a new car the first year, after they redesigned everything. No track record with the MM190. I would argue to go with the MM211 to ensure reliability. I would not go for the 190 unless the weight difference was important to me.Syncrowave 200, Millermatic 211, Victor torch, Propane forge....
