I bought a use Miller 250 Trail Blazer a couple years ago..and have a problem . When welding stick.Ill be welding along ,and all of a sudden it drops voltage and stops welding.It just has a light spark..I the turn it up to higher settings.and weld for a while.and then it kicks into high voltage..melting my welding .TO Hot...It does this back and forth..I just parked it last year.but I want to fix it..and ideals..maybe rectifier?? It has a gas 20 hp motor..nice shape welder..thanks guys in advance..
Miller 250 Trail Blazer drops voltage while welding stick
Yeah, but if any kind of varnish on the rotor tends to liquify (when the rotor gets hot) and make the brushes stick, thus you loose power. If the sliprings look kinda wavey and blackish, there is a film of oil on them. Took a while to figure this out while working on some troublesome machines, as the brushes looked just fine. Simple to test anyways.
Originally posted by cruizer View PostYeah, but if any kind of varnish on the rotor tends to liquify (when the rotor gets hot) and make the brushes stick, thus you loose power. If the sliprings look kinda wavey and blackish, there is a film of oil on them. Took a while to figure this out while working on some troublesome machines, as the brushes looked just fine. Simple to test anyways.
Originally posted by cruizer View PostA rectifier just doesn't work then not work, either does a board, unless its cracked in a certain way. I suggested cleaning your slip rings in a couple posts above. Maybe try that....
