Press brake talk
  • Portable Welder
    I'm not done yet, It shears 10' of 10 ga without a problem, I'm still waiting on the electrician to see if anything can be done to increase power, if not then my next step is modifying the pump to run less gpm.
  • JSFAB
    Originally posted by MMW View Post
    From post #4 of this thread.
    You can change out top & bottom dies to different shapes. Radius dies, step dies, etc. You can also use it for straightening & flattening plates & bars. A press brake is much more versatile than an apron or leaf brake.
    I agree with what MMW said here, a good operator can do amazing things with the right dies on a press brake. I will also add to his list, homemade dies, offset dies, and sectional dies. Offset and sectional dies can often be picked up cheap at auctions, simply because most people have no idea how to use them.
  • Meltedmetal
    Originally posted by Portable Welder View Post
    Now that I have my shear running.
    Glad you got it figured out. What did you do in the end?---Meltedmetal
  • MMW
  • Portable Welder
    Now that I have my shear running I'm inspired to get a press brake even more.
    What are the Pros and Cons of a apron brake verses a Press brake.
  • lars66
    Originally posted by JSFAB View Post
    Every hydraulic brake I've ever worked with had a high speed and low speed. The high speed was basically just a valve that opened up, whatever hydraulic oil was coming out of one side of the cylinders was immediately going to the opposite side, essentially doubling the speed. Once you got the limit switches set, good for production, not so good for fabrication.
    Mine is a mechanical break so has a high and low gearbox. Like you say high is just to fast for one of a kind bending .
  • JSFAB
    Originally posted by lars66 View Post
    My Cinci has a high and low transmission that is always left in low.
  • lars66
    Originally posted by Sberry View Post
    I see a unit in Farm Show, engineer built a hyd one and had the plans for sale and if I was interested would have to give this some serious consideration. Its been a while and I forget the cost but it was really nice. I think his was 10 ft too and in the 2-300 ton range. I like big ole slow for repair and general fab work. I have used many Cinci and some would really fly, not good for big plate, just plain too fast and a guy has to wonder how many guys caught a sheet under the chin.
  • Sberry
    The one in Farm Show Mag had a leveraged pitman arm. It ran from a small motor and seems had a cyl in the 100T range and leveraged 4 to 1 or so. Had a big jaw and opened wide.
  • Sberry
    A brake is a good move especially if you can come up with it at the right price. I am also in the sticks as far as power and was one of the reasons I never went in to the fab biz,,, or part of it anyway. I would have moved to town in an industrial park.
  • lars66
    been some time so the details are sketchy but I looked at the chart after bending 3/8" one time and it said 165 ton to bend the length I had with the die opening. Press break didn't flinch.
  • Sberry
  • Portable Welder
    Lars, I have a chart that says it takes 15.3 ton per ft. to bend 1/4" plate in a 2" bottom die so I would say your at the limits of your machine, However thank you for the confirmation as to what I might get by with.
  • lars66
    Trygn5, If I find the motor voltage cannot be changed then theres always the option of a transformer or just buying a new motor.
    Unfortunately, I do have to take the motor HP in to account since I only have single phase power and will use a phase converter to power it.
    MMW, Your example was perfect at 3 o'clock you have less power and max power is at 5-6 o'clock so its the tonnage at 3 o'clock that has to be big enough to bend 10' of 1/4" plate that I really need to be concerned about more than the max tonnage of the press brake.
    Let me know if this is correct
    My 150 ton Cincinnati mechanical will bend 1/4" x 10' in a 2" opening. Might have to do with die block height and where the crank is in the stroke tho. Hooked up 230 volt 3 phase.
  • Portable Welder
    Okay thanks for the terminology of air bending, Its just bending to the desired angle verses going all the way down, I've been doing it on a hydraulic accurpress for years and didn't know it had a name, Unfortunately the place where I use to get this stuff done at sold out and I doubt I will have the same relationship with the new owners.
    Not going to be a mom and pop shop anymore.
    Any way thanks for every ones opinion.
