What the amount of time a bobcat 225nt will run on a full tank of fuel. I have a job to bid away from any power source. I've ran the machine but can remember running it all day constantly.
bobcat 225 run time
bobcat 225 run time
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#Tags: None
Ok let. Me ask again differently. What amount of run time are u getting per gallon. Seems im getting only 1hr per gallon . Doesn't seen right thats why I ask..
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
Loaded to the tits, or idling, is the rpm set correct, what kinda oil and is it full what kinda airfilter, and is it clean, see alotta variables. I think there is a graph in the owners manual on fuel to output. Not sure though as I seldom have a need for an owners manual
If your so worried about the cost of fuel when bidding a job due to the fuel of the welder tells me your working way to cheap. you should be charging not less than $65.00 hr. to around $ 100 per hr. The average is $ 75.00 hr.
If your worried you might run out of fuel take extra fuel.
If the welder is not running good do a tune up.
Mist be nice to have no completion in your area .
I dont want to be over by much thats why I ask.
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
If your bid is coming down to the fuel as the factor if you make it or break it, you got problems. If it's a small job, I always throw in a couple hundred extra just to offset the little things....like running out of wire mid job, or you drop your angle grinder and break a cutoff wheel. I mean let's be honest, it costs about the same to fill up your welders fuel as it does to buy one multi flap. There is plenty of competition everywhere, there is also practical ways to bid jobs. Can you just charge a set price per day to cover your fuel? Like a flat $35.00 regardless of what happens, then no matter what your gonna be covered. Nobody makes it by constantly bidding close and "accurate", cause no matter what some gremlin will rear it's ugly head.
Originally posted by eecervantes83 View PostMist be nice to have no completion in your area .
I dont want to be over by much thats why I askAnd if a customers are looking for cheap I tellm don't call me.I,m good, not Cheap!
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
I have never been the cheapest.
I make sure my customers believe I will be the best choice because I will do a better job. I'm nearly always the highest by far.
Often times I try to get the "price shoppers" to go elsewhere.....it only seems to build resolve
Back on the Bobcat, what does your sparkplugs look like? How about your air filter? Have you tried fuel additives etc. ?
I have a 225NT and it is pretty much in need of a total engine rebuild. Once it gets to that point you may wanna get a newer machine. Mine is a 1997 model, and that is pretty old for a machine running on what is basically a lawn mower engine IMO. Yours may be cherry with low hours. Mine has had the living crap ran out of it, despite the fact that I am sentimental towards it
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
