older trailblazer
  • older trailblazer
    My trailblazer has 3200 hrs, I've changed most of the part's, thou lately the power up for welding sometimes has been finiky, sometimes it won't rev up when i strike an arc. Most of the time it run's fine thou after awhile it starts acting up, when i let it sit a minute or two it goes back to running fine, something w/ throttle advance or what! thx.
    Model & serial # may help.
    I assume you already checked all the electrical connections?
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      Too many trailblazer styles, and if you called into tech support the first thing they will ask is for the serial#. We CST Miller techs on this site need that info as well, so both pull up the correct tech manual and correct electrical diagram from the tech only sites. Other wise we can't do quat.
        yah checked connections, it starts fine runs good just have power up issues w/ it/ I'll get the serial nmbr in the morning started to rain a little while ago, thx for your help.
          miller legend nt serial number is KH 368332
            Just the name "Legend" tells me there is a throttle encoder on it. and its pooched (requires replacement)
              Where is the throttle encoder located at, whould that be that rubber round housing unit that the throttle pushes in and out of,anyway if i can see it i'll ask the miller mechanic here for the price, thx again very much appreciate your time.
