I was bored tonight. Thought I would run a few beads with a mig. Well, I fired up the 211. Things were going good until I heard a pop! Then the welds were all covered with brown smoke. I was blowing holes through the 16 gauge-like I had cranked up the amps.
I believe it is a gas problem. I always shut the valve on the tank-then switch it to spool gun and hit the trigger to bleed off the pressure on the system. Tonight, when I shut it off, my regulator didn't move.
What do you think? Cruizer! Got any ideas?
