Well, its starting after comming close to the work, so we know the high freq is working. So open open the bottom flap, in there where you hook up your cables, gas and such there is a High freq dial, merely turn that dial to max, then the Freq should come on full blast. Might want to set the High freq pont gaps to like 12 Thou then it'll really dance.
Synchrowave 300- No Output- Hi Freq Only??
Originally posted by slufkin View PostThanks to all the help on here, this machine is welding fine now. If only I could get the hang of using it..... but that's another problem.
Thanks for the help.
Progress might be easier if you spent some time studying the basics in the TIG Guidelines pamphlet .... that is if you have not already done so..
http://www.millerwelds.com/pdf/gtawbook.pdf
The Resource section also has a lot of TIG info as well .... the videos might illustrate the points better than the written word...
http://www.millerwelds.com/resources...ur-skills/tig/
additional good stuff at "WeldingTipsandTricks" and "YouTube".
