guys,
can you tell me what is going on with this weld ?
i see this problem from time to time when tig welding steel.
this particular job is a hydraulic housing and im trying to weld a new tube/fitting onto it. using .045" ER70S filler. rod is new with no rust on it.
i am only getting this problem in the area where the tube is over the hole which leads into the cylinder. the part and tube is 100% clean.
in another area where i just put a large tack to hold the tube to the housing to secure it when putting a wrench on it, it welded fine without this problem, elimination any filler, argon, or coverage problems, in my mind.
and this condition will pop up from time to time on different parts that never had any fluids through them, so im stumped.
i weld the best i can, use a dremel too to grind out the contaminated pockets, reweld, regrind, reweld... took me an hour to do this, and it should have taken 3 minutes...
oh yea, and when it is popping and making these holes, it contaminates my tungsten, kind of like its attracted to the tungsten..
any input is greatly appreciated.. thanks
