When ever i weld with 6011 it just has really high arc force and often times blows through my metal but when i use 7018 it welds flawlessly can anyone tell me what i can do to fix this.
Arc Welding 6011 high arc force
Originally posted by corcaminy View PostWhen ever i weld with 6011 it just has really high arc force and often times blows through my metal but when i use 7018 it welds flawlessly can anyone tell me what i can do to fix this.
Learn the differences and when, where and how to utilize each rod.
Simple, no, doable, yes.
Burn about 100 pounds of each rod and you will have it down pat.
Griff
6010-6011 is a deep penetrating, forceful, spray type arc.
7018- is low penetrating soft type arc.
As stated run at lower amps than 7018 and most time requires different technique to run.
Both have there place
Learn to master both & when to use.
Learn
