dynasty 200 help code 01
  • cruizer
    you have a zero output situation, failed mod and failed motherboard.
  • H80N
    Found 1 not 01... assume they are the same..
    Page #54 in the manual
    7-3. Voltmeter/Ammeter Help Displays
    http://www.millerwelds.com/om/o2240aj_mil.pdf
    "Help 1 Display
    Indicates a
    malfunction in the primary pow-
    er circuit caused by an overcurrent condi-
    tion in the primary IGBT switching circuit.
    Contact a Factory Authorized Service
    Agent "
  • FusionKing
    Help 01 I don't know what that is.....
    Call Miller
  • mandmech
    started a topic dynasty 200 help code 01
    have a 6 month old dynast 200 dx, about 20 hours on it. half way through a weld output stopped, help-01 displayed. turned power off and then back on and all seems good till pedal is depressed then help -01 displays. it does this with the pedal control, or if the output is turned on with lift arc. tested with different power inputs, 120v and 230v... same results. anyone know what this means?
