I was curious if there are many different ways people use to attach the work cable to the welding bench as far as what they clamp it to? Like on my 1/2" thick table I just clamp it to a clean spot and have run that way for years. Then I thought it would be nice to have a helper work clamp that I could clamp to the part but not remove the main work clamp from the table. Has anyone welded a large bolt to their welding table where they connect the main work clamp, and then connect a short jumper type cable to the same bolt to connect to their work? Just wonder if it is a common practice or a dumb idea... Some parts are odd shaped and need a direct connection to the work clamp.
Thoughts?
Thanks,
Grumple
Thoughts?
Thanks,
Grumple
