Mister Bill
  • Mister Bill
    Is there a proper way to set up the amperage on a XMT Series welder with the V sensing selection? I am using a X streme 12 VS suitcase wire welder this system is hooked in with rolling positioner for doing 6" sched 80 coupons (pipe). The LED for amperage only reads while making the weld and of course it pulse's. Im doing a lot of guess work I need to to put a root in and pass an X ray. Can somebody help me out?
    Well, your setting up voltage not amperage in CV, Pulsing? Probably not unless its a MPA. Alot of variables here, maybe just use Millers Weld Calculator.
      Bill welcome to the forum.
      Lincoln A/C 225
      Everlast PA200
