Seeing as my unit is past its warranty period and I've absolutely had it with these terrible cables, I'm going to put some Dinse connectors on the front panel. Since this is the 180A model, should I look right past the small 3/8" connectors and jump right for the large 1/2" connectors?
Retrofitting Diversion with Dinse connections...
If you find the part number for the flush fit style dinse connectors. Post it up I've been wanting to add them to a couple of my machines to rid of the ground cable when not in use or moving.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Originally posted by Cavi Mike View PostSeeing as my unit is past its warranty period and I've absolutely had it with these terrible cables, I'm going to put some Dinse connectors on the front panel. Since this is the 180A model, should I look right past the small 3/8" connectors and jump right for the large 1/2" connectors?
and get one of these for the torch... it will allow you to switch torches with little fuss..
Originally posted by H80N View PostI would get the large ones (50MM)and use a "gas thru" panel dinse for the torch connector like on a Maxtar 150 STH & Lincoln Square Wave TIG 175
http://store.cyberweld.com/tigtopoadflt.html
Originally posted by Cavi Mike View PostConcerns with leaking with the gas-thru design? The only gas-thru panel connector available is the Miller replacement and it works out to over $30 after shipping. Not worth it if it's just gonna leak in a couple years.
Heck I have an old Lincoln Sq Wave TIG 175 that had one and never leaked in 14 years... bet if I dusted it off and tried it now it would be fine...
Maybe somebody else like Cruizer has other opinions... but my experience was trouble free...
Personally, I don't see the point, torches and parts are cheap. Why try to make the unit into something its not. And if it breaks, your not making it any easier for us to repair..
I'd refuse to repair the unit if someone modified it. people try to modify stuff all the time. Being a welder repair guru, what do you think I'd tell them, and where they can go.....
Originally posted by cruizer View PostPersonally, I don't see the point, torches and parts are cheap. Why try to make the unit into something its not. And if it breaks, your not making it any easier for us to repair..
I'd refuse to repair the unit if someone modified it. people try to modify stuff all the time. Being a welder repair guru, what do you think I'd tell them, and where they can go.....sigpic
Originally posted by Cavi Mike View PostIf you're such an expert, maybe you should actually do some research on this welder before you make [email protected] comments. Now you can go f*ck yourself and get out of my thread because I will make sure you will never get your hands on anything I own.
What research of this welder would change anything about what he said. He merely stated that as a certified miller tech, he would prefer it to be in factory condition. If I was you, I would just sell that little diversion and get a dynasty, then your torch dilemma, and underpowered machine dilemma are both solved.
Originally posted by Cavi Mike View PostIf you're such an expert, maybe you should actually do some research on this welder before you make [email protected] comments. Now you can go f*ck yourself and get out of my thread because I will make sure you will never get your hands on anything I own.Glen
Miller Dynasty 200DX - Millermatic 350P - Hypertherm Powermax 45 - Hobart Handler 150
You may not like Cruizer's response... but he is a very knowledgable TECH that provides helpful ... valuable advice on a daily basis.... and his was a very valid viewpoint
your nasty response will not encourage experienced folks to waste their time responding to your questions..
When you slammed that door you appear to have slammed your oscar mayer in it at the same time....
good way to impress the troops when you introduce yourself in a new neighborhood..Last edited by H80N; 11-02-2014, 04:43 PM..
