I 'm trying to build something similar to these stalls. The first issue I'm hitting on the materials is getting the channel that the 2x6 boards will fit in, there is something called Horse stall Channel. I can not find a source locally though, my local steel distributor doesn't carry it.
I got a quote to take 14 gauge steel have it sheered and braked into the channel. The 4x10 sheet metal is $85, the labor for the work is $255 ($340 total) and will yield 90 feet of channel.
Another option is to take strips of 1 3/4 flat stock and weld 3 pieces to form the channel. I need to price the flat stock out, but assuming the material is cheaper and I don't mind the time welding, what do you think of this solution? I'm guessing I'll clamp the pieces to a piece of square tube as I weld to keep it in place, but these will be long pieces so I'm nervous how it will come out.
