I recently purchased a diversion 180 as my beginner tig machine and I replaced the torch assembly for a wp9 flex head and now my only problem is the rubber supply line hose is too stiff so I am asking is there any way I can change the supply line to a flex line...? Thanks for reading and answering my questions.
Diversion 180 question
Check out YouTube, you will find some guys that have actually done it. One I've seen in the past the guy sells the replaceable part to do it, he makes them. Just spend a little time and you might find it. Try searching Div 180 torch swap or something similar. Good lucksigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Originally posted by Argon_addict View PostI recently purchased a diversion 180 as my beginner tig machine and I replaced the torch assembly for a wp9 flex head and now my only problem is the rubber supply line hose is too stiff so I am asking is there any way I can change the supply line to a flex line...? Thanks for reading and answering my questions.
"Air-Cooled TIG Adapter for Miller Diversion Machines"
Arc-Zone has a wide variety of TIG connectors for any job you may be doing. Choose the type of connector you need and buy it from Arc-Zone.com today.
It will allow you to replace the torch with any standard air cooled one... including the ones equipped with superflex hoses....
Good to see they are catching on and being distributed!
Good Bird Dogging, H80N!sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
40 ton press brake
Originally posted by ja baudin View PostGood to see they are catching on and being distributed!
Would have thought that Miller would have used an industry standard fitting from the get go....
can't see where they saved any money with that oddball fitting..
Good thing that HTP decided to fill that niche for Diversion owners...Last edited by H80N; 10-27-2014, 05:31 PM..
