Hooked up my newly acquired 250dx and man it takes a lot of amperage to run these machines.......or is some thing not right,
I'm running it on 220 volts!!!!
AG
YUP...
that machine wants to see approx 92-96 Amps @ 220 Volts for full output..(without PFC...)
A lot of homeowners get away with a 50 or 60 amp breaker to run these with a 50 amp plug/receptacle. I believe it's a 6-50p & r.
MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
That is true... they just run them at reduced output... which works out fine for most automotive TIG applications...
there have been several threads on it over the years.....
if you do a search on "dryer power" you will find some threads where folks have a similar dilemma... there are a lot of full sized transformer machines humming along happily in home garages at reduced power..
AND yes... the NEMA 6-50 has become the defacto standard plug in most places for welders running single phase 220 volts... (right or wrong... it seems to be the connector of choice)
Does it make sense to have a machine like this and not using it ......I went and got a 200 amp entrance installed.But in the long run it will also be a safer system.
I weld 70-80% percent aluminium which takes more power!!!!
AG
Having the full amperage capacity available is always preferred... but some home hobbiests simply do not have that option...
of course.... one could opt for an inverter like a Dynasty that requires much less input amperage...
You think that 250 is hard on power... Try a 350 on 200 amp single phase service. Yea I have to be careful or I can put the lights out. Full bore burning it down on a head= turn out most of the lights and don't dare let dad start the 30 horse rotaphase for the air compressor or mill. Oh got the new Quincy in service finally.
Dynasty 400 Wireless
Coolmate 3.5
Aerowave loaded with Sequencer and pulse
Watermate 1A
XMT350 CC/CV
S74DX Feeder
Optima Pulse Pendant
WC24
30A spoolgun
Neverlast 100 amp plasma with Hyper Duramax torch
Avortec 280 mig
GO CNC Poweredge CC/CV pulse and double pulse
Harris Old school 2 stage Oxy/Ace
Victor flow meters
Flametech Duel flowmeter
Just a hilljack in the woods with fancy welding equipment
and a pet Raccoon.
We hear a lot of conversation about how many amps we have available. Driving around VT, I see a lot of 15 Kilowatt transformers. This is 62.5 amps. In many cases you share a transformer with neighbors. If your welder pulls voltage down too low, your neighbors won't be very happy with you.
Dynasty 280DX
Bobcat 250
MM252
Spool gun
Twentieth Century 295
Twentieth Century 295 AC
Marquette spot welder
Smith torches
