I have a Millermatic 252 and it eats tips like M & Ms This is very annoying and expensive any Ideas
Millermatic 252 Eats Tips and about 1 in 10 bad Starts
Originally posted by Richard Baird View PostI have a Millermatic 252 and it eats tips like M & Ms This is very annoying and expensive any Ideas
what you are welding.. material & thickness
machine settings
gas & flow rate
wire type and size... brand...
contact tip size and style...
wire stickout
not to mention some pics of the "eaten tips"
If your using real Miller tips, you likely won't have this problem. If you are then its obvious that your wire is slipping.
See, we don't read minds, absloutely no idea how old your gun is, if you've ever changed a liner, if your using clone (cheap) tips, condition, or correct size of your driver rollers,
Sorry, I just went back and re-read your original post, and the title. Sounds like you are burning back and fusing the wire to the tip.
If it is not due to incorrect voltage/wire speed settings, open the machine up, check your capacitors. This happened to me with my LN-25, the capacitors were broke loose, bouncing around at the bottom, we replaced them with new, more secure mountings, no more burning back, or wasting tips.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
A welder such as the MM252 could burn tips and stick the wire if, as mentioned above, the wire is slipping in the rollers. Also, the user could have set way too much voltage and too little wire speed. It could also be a dirty liner or corroded wire.
On my MM252, I changed the outer cover on the original torch to the one that permits a 1/8" recess for the tip. This shields the tip a bit more. I've yet to burn a tip, however, after a year of intermittent usage. I use only original Miller parts.Miller Syncrowave 200
Milermatic 252
Lincoln AC/DC "Tombstone"
Originally posted by Synchroman View PostA welder such as the MM252 could burn tips and stick the wire if, as mentioned above, the wire is slipping in the rollers. Also, the user could have set way too much voltage and too little wire speed. It could also be a dirty liner or corroded wire.
Originally posted by ericher69 View PostI did just the opposite. Tip flush and no issues
Originally posted by ericher69 View PostIt is PERFECT! In the shop with NO air movement.
Silly is chastising someone without knowing what works for them.
Gee.... if it were me...
I might have a tendency to listen to Cruizer's voice of experience.
instead of getting all chafed......Last edited by H80N; 10-12-2014, 05:50 PM..
I bought off brand tips for my M-25 gun, as the LWS didnt have any Miller tips. I have been having similar issues with the gun using them. It keeps shorting to the tip, and I have gotten a bunch of birdnesting with .035 wire. I have never had issues with birdnesting with.035 before. Going to change back as soon as I get to the weld shop again. What a pain.
