No brainer. Stick. You don't have enough machine to wire weld.
Griff
Yea thats what I was leaning towards. Got everything prepped for tomorrow to weld in-place. What size rods would you recommend? I don't weld 1" enough to be familiar.
out of curiosity what size mig would one need to weld something that thick and if I had one that big , then which would be preferred mig or stick?
Neither one. Weld clips to the 8" flat and bolt it I to the web of the chassis
Dynasty 400 Wireless
Coolmate 3.5
Synchrowave 350LX loaded with Sequencer on the cooler
XMT350 CC/CV
S74DX Feeder
Optima Pulse Pendant
WC24
30A spoolgun
Neverlast 100 amp plasma with Hyper Duramax torch
Avortec 280 mig
Harris Old school 2 stage Oxy/Ace
Victor flow meters
Flametech Duel flowmeter
Just a hilljack in the woods with fancy welding equipment
and a pet Raccoon.
Normally some preheat would be part of the plan for one inch. Especially when there is such a disparity in thicknesses. Seems like any amp setting high enough to get good depth of fusion on one inch would be likely to turn the relatively thin frame material to crispy bacon like material.
Sound like u have no idea what he doing . Just pay and have the gooseneck plate installed by professional.
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
(Retapped to fit regular mig tips)
Work better & less parts to stock.
Miller 130xp
T/A Dragster 85 (portability 11 pounds)
Oxygen/Acetylene torch set 50'
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
Coolmate 3.5
XMT350 CC/CV
S74DX Feeder
WC24
30A spoolgun
Avortec 280 mig
Victor flow meters
and a pet Raccoon.
I don't know..... I have had a 98 Dodge ram 3/4 ton with a plate welded in now for 10 yrs and its actually a 6 inch wide plate ( the new one 8" ) it hasn't shown any signs of breakage. I pull 10,000 lbs plus everytime I hook a gooseneck to it.
Could you describe exactly what you have? A gooseneck "plate" is a 2' by just wider than the frame 3/8 or thicker piece of plate steel with a buildup and 2 5/16 ball in the center that bolts through the sheet metal bed into the frame. I'm assuming by your speech you didn't weld that to the sheet metal. Did you weld a piece of channel on between the frame or something similar?
Disregard the above, I reread the first post and understand now.
How many passes? What rod and heat? Did you take off the bed to weld topside? Pictures?
