I am a new welding teacher at a high school. I have all new miller in my lab and I was mainly taught on just the old millers with the 6 and 60 short circuit. I have gotten both of them to run short circuit for my student. The other day I had a student do something I have yet to figure it out what he did. One of the Millermatics won't go to short circuit any more. I can set it and it will run a few second on short and then switches right to spray. I have reset any possible timers that could of been on there. I am learning as I am going and could really use some ideas so I can get this one up and running so my students can use it.
Millermatic 252 problems
Try a reset on the machine, owners manual should illustrate how.sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
You might also check with the LWS that supplies/supports your school. They should be able to help, especially if the equipment is new - it was possibly bought through them. I know that the LWS that supplied the vo-tech school I recently graduated from provided great support for our equipment.
The difference between short circuit and spray is just different wire speeds, voltage settings with 90/10 vs. 75/25. I don't think it can actually go into a "spray mode" as it doesn't have different modes. Sounds like a kinked liner or something restricting the wire feed.Dynasty 400 Wireless
Coolmate 3.5
Synchrowave 350LX loaded with Sequencer on the cooler
XMT350 CC/CV
S74DX Feeder
Optima Pulse Pendant
WC24
30A spoolgun
Neverlast 100 amp plasma with Hyper Duramax torch
Avortec 280 mig
Harris Old school 2 stage Oxy/Ace
Victor flow meters
Flametech Duel flowmeter
Just a hilljack in the woods with fancy welding equipment
and a pet Raccoon.
