Hello all,
I purchased a valved CK trimline210 with a one piece superflex cable. My next move is getting it connected to my Maxstar 200 STR. I need a Dinse with a gas line so I can get gas to my torch.
I have a couple of questions. When determining which adapter to buy, I've run into a few snags. First of all, I came across this part by CK, and its described almost like a special connector made specifically for my torch. I don't really understand what could be different about it. These sales ads are very frustrating as they do not give all the specs on the fittings.. drives me nuts. So aside from advertised carrying capacity.. is the female fitting inside these things a different size for different torches? The trimline210 is advertised as being compatible with 17 series parts.. but in the case of the connector, stalled on what to do...
I have choice of a 17 compatible 150 Amp, a 26 series 200 amp.. or this "made for TL210 CK clam shell Safeloc contraption.(may have an advantage since I wouldn't have to patch in more gas line if I keep it close to the flow meter).
Here's a link to the CK product.
(SafeLoc Clamshell thingy)
https://www.arc-zone.com/index.php?m...68dhd4c3odahh3
Otherwise, could I use either of the standard Miller adapters?
Part# 195378 OR # 195379
These look the same but are rated 150 and 200 amps respectively. One is designated as 17 series compatible one is 26 series. Aside from carrying capacity, should I expect different sized female fitting inside of each connector or are they the same?
Any insight would be appreciated. I'm trying to gather up all needed components and I keep hitting road blocks!
Many thanks.
Many thanks.
