There are 3 "Field Options" they should be a Plug n Play...
Sequencer Module
#300 547 Field Kit for Syncrowave 250/350 Effective with serial number LE282983.
Provides a starting current higher or lower than the welding current. Provides final slope and final current for trailing the weld. Provides spot timer for TIG spot application. Pulser Module
#300 548 Field Kit for Syncrowave 250 DX Effective with serial number LE282983.
For welding of thin materials. Provides a heating and cooling effect of the weld puddle to reduce heat input and control distortion of the material. Provides 0.25 to 10 pulses per second. Power Factor Correction Kit
#194 692 Field Kit for Syncrowave 250 DX
Reduces primary amperage draw by approximately 25 percent allowing the use of smaller breakers/fuses and smaller primary cord. Power Factor does not reduce the power consumption/electrical bill.
10 pps would drive me crazy, and is almost unusable to me as 60pps is mimimum to prevent nausea and headache from the strobelight effect. 100pps to 500pps which I use on a daily basis works a charm.
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
I really like pulse on thin copper. I don't need to ride the pedal quite as hard that way, I get penetration without sag. I usually have it set to around 1.3 pulses per second, not too annoying. I agree that 10 pulses per second would drive you crazy.
If you don't weld thin materials, not sure if slow pulse would help that much. My Syncrowave 200 will not go faster than 10 pulses per second, so I have no experience with higher pulse rates.
Syncrowave 200, Millermatic 211, Victor torch, Propane forge....
