Need help with trying to setup a XMT 350 MPa to pulse mig weld with 12 VS Suitcase!
  • Need help with trying to setup a XMT 350 MPa to pulse mig weld with 12 VS Suitcase!
    Anybody pulse mig weld with XMT 350 MPa and a 12 VS Suitcase?
    I would think with the 12vs being an across the arc set up that wouldn't work ....12rc prob would be fine , you will need a feeder with the 14 pin connection ....as an aside the 12vs isn't great for mig , it's ok at a pinch but it's more of a fluxcore unit ....
      Blank blank blankkadee blank blank CRUD!!!!!! Well with that all out does anyone want to sell a used 70 series feeder
        Ahh, no you need a $$$ MPA feeder. getting a standard 70 series, will not get you any farther...
        The S-70 feeder has no internal programming for a MPA power source, so no way in heck its going to work.
        If you had a Optima hooked in between the power source and feeder, then possible. I mean that the MPA power source has no way of using its pulse functions with out some machine telling it what to do...
          It works good. I have the same set up. A miller tech should be able to get you through it. If not pm me.
          Mike
          MD Welding & Fabricating L.L.C.
          [email protected]
            yep Marty at miller walked us right though the setup and the suitcase 12vs works great for pulse welding. That xmt 350 mpa is some kind of set up. Rick at miller helped us get started on the settings and we are good to go. anybody using this combination just needs to set the xmt into manual setup mode (turn machine on while holding down the setup button) and then its not hard to figure out. I have used this 12vs for everything for years hooked to a trailblazer been a great machine. only thing they told me not to coil my leads will mess with the pulse
              Also Thanks Mike for the reply
                Well I'll be....
                  MPA power source requires a MPA feeder to work correctly
                  Dynasty 400 Wireless
                  Coolmate 3.5
                  Aerowave loaded with Sequencer and pulse
                  ​Watermate 1A
                  ​Coolmate 3
                  XMT350 CC/CV
                  D74DX Feeder double the fun
                  Optima Pulse Pendant
                  WC24
                  30A spoolgun
                  Neverlast 100 amp plasma with Hyper Duramax torch
                  Avortec 280 mig
                  GO CNC Poweredge CC/CV pulse and double pulse
                  Harris Old school 2 stage Oxy/Ace
                  Victor flow meters
                  Flametech Duel flowmeters
                  Just a hilljack in the woods with fancy welding equipment
                  and a pet Raccoon.
                    Thas what I thought too, apparently thats not the case. The XMT MPA can be set up manually. The problem here is that being manual, the feeder will not recognize, nor compensate for wire stickouts and likely go wonky. The MPA feeders are synergic.
                      Well i have used the suitcase on pulse mode for 2 days now and am very happy with the results. The speed is greatly increase over mig and i can be kinda lazy on the out of position welds that we deal with and still have good welds, I am sure that the 74 series mpa feeder would be better because its synergic to the xmt and i would only have to deal with one setting but i am really surprised how easy this is to dial in. still would like to buy the mpa feeder one day.
