Hello all, I've been reading this forum for years and have gained a ton of knowledge, but this is my first post. I've been welding with a mig for several years now and about a year ago moved up to tiging with a little ThermalArc that I got on CraigsList for $300 with the bottle and regulator included.I finally upgraded the other day to a Syncrowave 250CC (a STEAL of a deal again on CL) and need help wiring it. The last owner had it hard wired, but I want to add a plug. There are 4 wires, but because 1 of the wires (white) is cut much shorter than the others (almost completely covered by the rubber seething) I don't think that last owner used it. Exposed are the red, black and green wires.Does anyone know how to add a 220 plug to this? Any help would be greatly appreciated.
Just bought a new Syncrowave 250CC, need help wiring it
Originally posted by DBookatay View PostHello all, I've been reading this forum for years and have gained a ton of knowledge, but this is my first post. I've been welding with a mig for several years now and about a year ago moved up to tiging with a little ThermalArc that I got on CraigsList for $300 with the bottle and regulator included.I finally upgraded the other day to a Syncrowave 250CC (a STEAL of a deal again on CL) and need help wiring it. The last owner had it hard wired, but I want to add a plug. There are 4 wires, but because 1 of the wires (white) is cut much shorter than the others (almost completely covered by the rubber seething) I don't think that last owner used it. Exposed are the red, black and green wires.Does anyone know how to add a 220 plug to this? Any help would be greatly appreciated.
So it's Not a 220 volt welder.Last edited by nfinch86; 09-16-2014, 12:19 PM.
If it's a regular Syncrowave 250 AC/DC, should be just two hot wires and a ground. Can be jumpered for different input voltages, so you might want to double check how it is set up unless you know the guy was using it on 240V.Miller stuff:
Dialarc 250 (1974)
Syncrowave 250 (1992)
Spot welder (Dayton badged)
The previous owner probably used 4-wire cord because he had it on hand.
You only need 3 of the wires- that's why the white wire is cut short and not used.
Buy a 6-50P and use the wires that are exposed on the existing power cord.
Green to the rounded post and the other 2 wires go to the flat blades--Doesn't matter which one as they are interchangeable.
and check the input voltage as USMCPOP said.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
Originally posted by nfinch86 View PostI'm not an electrician, but I think 4 wires = a 3 phase machine !
Out of sheer curiosity, what is a fair price for this set up used? Included was a Radiator 1A torch cooler, a 180 tank (full) and a very sturdy = heavy cart to hold it all. Plus the guy threw in 7 clamps, 2 were Mac and the rest were "no names." Isn't the bottle alone worth over $200?Syncrowave 250CC w/ Radiator 1A
Millermatic 130XP
Spectrum 125C
Here is a link to the manual... just plug in your serial number to get the correct version..
http://www.millerwelds.com/service/ownersmanuals.php
The manual will answer a bunch of questions including "Strap" positions for your available shop voltage....
Originally posted by DBookatay View PostIt's defiantly a 1 phase, says so right on the serial number plate on the front.
Thank you Broccoli1, I'm going to wire it tonight then. The reason I want to add a plug is because I am using it at my house, and the laundry room is right next to my garage, so until I can fully tackle adding a 220 in the garage I can just unplug the dryer.
Out of sheer curiosity, what is a fair price for this set up used? Included was a Radiator 1A torch cooler, a 180 tank (full) and a very sturdy = heavy cart to hold it all. Plus the guy threw in 7 clamps, 2 were Mac and the rest were "no names." Isn't the bottle alone worth over $200?Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Originally posted by cruizer View PostWhats the seial# so that I can pull it up, never heard of a Synch 250 CC
CC ac/dc 1- phaseAttached FilesEd Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
Just note that you will not be able to run it at anywhere near full power off of that 30 amp dryer outlet. I don't think that you are going to have much luck plugging that recommended 6-50 P plug into that outlet either. Match the plug to the outlet and run at reduced power and you will be OK until you get the correct power line and outlet run. See your owner's manual for the input/output power curve.
Originally posted by davido30093 View PostJust note that you will not be able to run it at anywhere near full power off of that 30 amp dryer outlet....Miller stuff:
Dialarc 250 (1974)
