I'm new to this sight trying to find some help with my big 40 I used it a week ago welded fine started it today and it doesn't produce any weld output but will produce 110 out of receptacle checked brushes they are free not sure how to check other components any thoughts thanks in advance this is a late 70's machine
Miller big 40 won't weld
You Can Down Load the Big 40 Operater Book from Miller Web Site
Hello Sir,I have a Miller Big 40 Welder, along with other Miller welders. I wrote down my Serial Number and Model No# and down loaded the Operator book from the Miller Web Site. The Operator manual has/ or could have some Trouble Shooting Information in the back of the operator book.
Also, a man on another welding forum emailed me a higher ended service guide for my Trail Blazer 250 G. This Service Manual had a complete listing of Voltage Checks, etc., and it worked great to trouble shoot my Trail Blazer 250 G. Perhaps, someone (here) can help you more... if they had a Service Manual for you Big 40 Welder and emailed it to you.
AveryLast edited by HighFly27; 09-12-2014, 01:22 PM.MM 251 w/ Spool Gun, Trail Blazer 250 G, Bob Cat 225 G, Miller Big 40, Lincoln 400 w/ Tig Unit, Lincoln 300 Classic, Gas, Lincoln LN 25, ESAB Power Cut 1500 Plasma Cutter, Ford F-700 Service Truck w/ 12 K Crane, (2) Lathes, (3) Milling Mach's., (1) HD Radial Arm Drill, (2) Eng. Dyno's., & Diesel Eng. Repair Tooling
