Does anybody use their pulse function and for what purpose?
Dynasty 200 dx pulser
I do. Some uses I've found:
- 1PPS for thin material square tube butt joints along the radius corner, where there's a big gap
- high PPS for reducing heat input on thin material
- high PPS for directing the arc, whether close to an edge or right into the root of a fillet
High speed pulse is particularly effective in agitating the puddle for faster seam closing on DC, less arc wander, hence faster travel speeds.
With the probability of ridicule, I think DC H-S-P flares the arc, hence colder weld and less penetration. Some of which can be modified with tungsten profile.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
Originally posted by 11b View PostDoes anybody use their pulse function and for what purpose?
I use pulse all the time at home. I just finished a project with 16 gauge square carbon tubing. the joints weren't tight. I used an abrasive saw to cut them. The pulse function on the Dynasty made it easy to fill the gap.
You just have to remember-when you pulse, you have to increase your amps. I use the "rule of thumb", double the amps for what you are welding. Then adjust with your amptrol. Good luck!
I use pulse all the time as well, although I havent seen any real benefit to it at least in my case.
If I reduce the pulse rate down to 1 pps I think it helps but it drives my eyes nuts, so I dont use it on the low settings. I weld material that is .022 thick, butt weld, run at 19 amps, 50 pps,50 percent and 20 percent background, I can turn off the pulse and reduce the current to (10 amps or so) the same as the average current with the pulse on and it seems to weld the same for me on this light gage material. I have read articles where guys use it and swear by it, it just doesnt do much for me on the mild steel pipes.
I do like the variable frequency for aluminum welding though.
Overall I really like the 200dx as it pretty much does all I need to do, since 2009 I havent had any major problems with it. It has less than 400 hours on it.mike sr
