As I do research on my Millermatic 200, I see lots of variations. Some have "CP" in front of the 200, some have white panels, etc. etc. I'll try to post a picture but have had zero success doing that from my desktop. I guess I'll describe it in words: Black panel, SKP-35 unit top right corner, SN K8052215, Says "Millermatic CV-DC-ARC welder, power source/ wire welding". So, my question is how many variations were there and which one is the most desirable?
Millermatic 200, how many versions were there? Which one do I have here??
There a few different versions. The skp panel has had quite a few issues, and is somewhat outdated. All of the versions were/are good. The only realissues are terminal connections on the back of the front panel, and after 30 years the capacitors get weak. New caps and the machine is good as new.
Get your machine plugged in and weld with it and stop worrying wether yours is a really really realy good welder or just a really really good welder.
Originally posted by walker View PostThere a few different versions. The skp panel has had quite a few issues, and is somewhat outdated. All of the versions were/are good. The only realissues are terminal connections on the back of the front panel, and after 30 years the capacitors get weak. New caps and the machine is good as new. Get your machine plugged in and weld with it and stop worrying wether yours is a really really realy good welder or just a really really good welder.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
Double check your SN. Second character should be a letter not a number.
In a nut shell, ALL MM200s are good machines and there were/are 4 basic "generations" with a few subtle internal changes along the way making what I call "sub-generations". As for white face-vs.-black face, I can't tell you what SN the black face made its appearance but the MM200 started out with white.
Gen 1 - No polarity change capability, spot weld only control, 4-pin receptacle for Spoolmatic 1 direct connect spoolgun.
Gen 2 - Added external polarity change capability.
Gen 3 - Replaced spot weld only with SKP-35 spot weld/pulse control.
Gen 4 - Replaced 4-pin with 14-pin spoolgun control receptacle for Spoolmatic 3 direct connect spoolgun (and later for use with current WC-24/Spoolmatic 15A/30A weld control/spoolgun combination).
Within these basic generations were "sub-generation" internal changes that included Fan-on-Demand, changing from a 4-wire to 2-wire feed drive motor and an increase in weld output capacitor operating voltage and capacitance rating that remained for the remainder of their production.
As for your capacitors, if it's real low hour machine as believed I wouldn't worry about them unless there's an indication of a problem such as one or more leaking, obvious failures (swollen housing or blown open) or good welding performance requires a significant higher setting than called for in the recommended setting chart that could be an indication of weak caps.Last edited by duaneb55; 09-08-2014, 11:24 AM.MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
*WC-1S & Spoolmatic 1
PakMaster 100XL
Marquette "Star Jet" 21-110
You are correct!
Rechecked the serial number and it's KB, not K8. Mine has the 14 pin connector. I've been able to find the WC-24, Spoolmatic 30A, and Roughneck gun so should be all set. I've been told to run .030 wire for this machine as I'll be welding metal 1/4" or less probably. The capacitors all look fine and I believe it's right on with the thickness/welding recommendations printed so I'll quit worrying about that. Thanks for the help.Millermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
Originally posted by denwhit View PostRechecked the serial number and it's KB, not K8. Mine has the 14 pin connector. I've been able to find the WC-24, Spoolmatic 30A, and Roughneck gun so should be all set. I've been told to run .030 wire for this machine as I'll be welding metal 1/4" or less probably. The capacitors all look fine and I believe it's right on with the thickness/welding recommendations printed so I'll quit worrying about that. Thanks for the help.
From what I am seeing it was the last and latest version..
here is the manual..
http://www.millerwelds.com/om/o1303p_mil.pdf
I could be wrong but I counted 14 versions of the MM200
http://www.millerwelds.com/service/l...&submit=SearchLast edited by H80N; 09-08-2014, 04:02 PM..
Originally posted by H80N View PostYour KB052215 Serial MM200 is Early to Mid 1991 manufacture....
http://www.millerwelds.com/service/l...&submit=SearchMillermatic 200
Miller TB 251
Miller roughneck
WC-24
Spoolmatic 30A
Originally posted by denwhit View PostI see in your signature, you own one too. Are there any parts, ie; drive rolls, ect. that one should stock up on in case they get hard to find in the future?
rolls for my MM350P will fit the MM200... so no worries..
the full sized 3 legged rolls are common throughout the industrial range...any LWS should have rolls..
BTW..The small rolls (4 legged) will NOT fit your MM200.. those are for the light duty or hobby grade machines..Attached FilesLast edited by H80N; 09-08-2014, 06:28 PM..
Originally posted by H80N View PostI could be wrong but I counted 14 versions of the MM200MM200 w/spot controller and Spoolmatic 1
Syncrowave 180 SD
*HF-251D-1
PakMaster 100XL
